`78 cafe-inspired build thread
Got the drive axle and gears out last night.
The dogs on 5th that mate with 2nd have definitely already had the "dremmel" fix done.....but I don't think it was done right. The dogs are SEVERELY back cut (dovetailed), I don't think it's possible for them to mate on a flat surface with the slots in 2nd gear.
I also don't think the gears are installed 100% correctly on the axle. Looking at the diagram now (don't have the parts with me), I feel like there may have been a circlip missing on my transmission between 5th and 2nd. I can't remember right now, I'll check that also when I clean the parts up.
I didn't see anything I didn't like about 5th gear or the inside of the casing on the drive axle....what else should I look for that causes the 5th-gear grinding noise (very light) on the freeway? I'm more concerned about this than the 2nd gear issue...
I'll take some pics after I degrease and clean up all the parts so I can better inspect them.78 EComment
Sep. 12th 2015
RIPComment
Yup, if that big circlip is missing between 2nd and 5th, it will let 2nd get too close to 5th and do what you were describing.Try your hardest to be the kind of person your dog thinks you are.
I'll take some pics after I degrease and clean up all the parts so I can better inspect them.Life is what happens while your planning everything else!
78 XS750Comment
That's good. As you already noted it ran great at that setting 25.7mm. I did a series of TESTS a long time ago and IIRC there was little to no difference in the floating height of plastic vs brass when measured at their respective measuring points.Life is what happens while your planning everything else!
78 XS750Comment
5th gear dogs...
Slots on 2nd gear...
Seems that 5th gear was contacting its shift fork...
5th gear has irregular chamfers all the way around the edge, makes sense since it was contacting the fork...
I can't tell with my eyes whether the fork itself is bent, they don't have a very uniform/precise shape to them to begin with. I am replacing the forks with the ones coming with my parts transmission.
My main question is how 5th touched the fork. Is it only possible with a bent shift fork?
I checked again, and it looks like the gears were installed correctly, along with the circlips and washers.78 EComment
Ok, so 2nd gear was in place along with its proper circ-clip. As I mentioned in your other thread, looks like someone had second gear slipping issues and stood on the shift lever to hold the gear in place, causing the grinding on the shift fork you see.
Given the tightness of all the gears and such in the case, the decreased width of the shift fork where the gear rides, MAY allow for 5th gear wheel, when in 5th gear, to move further toward the engine case than designed. Based upon the wear on the case side of the gear, it would appear it has.
And yes, someone went WAY overboard on the lsope of the "dovetailing"!Interestingly enough, it does nto appear they put any slope on the slots in 2nd gear. If you look at the tech tip on the dremmel repair, it shows how it is the combination of both gears being back-cut that forces them to pull together and resolves the slipping issue. Only cutting one does not really solve the problem.
Sounds like your on the correct path with the new gears and fork(s). I would check the fork on 4th gear as well, and back-cut the "new" 1st, 4th, 2nd, and 5th gears if they have not been done yet.Life is what happens while your planning everything else!
78 XS750Comment
Question to the transmission gurus...
Well, the fork that drives 5th also drives 2nd gear and problems usually start with 2nd... is it possible to bend the fork trying to keep it in 2nd gear to the point it contacts 5th like you are seeing...?'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
Marshy, we just had a pretty in depth discussion in his 5th gear issue thread on how the transmission works. 2nd gear never moves, but the shift fork shown slides 5th gear on the countershaft toward 2nd gear so its dogs interlock with the slots in 2nd gear. Looking at his second gear, you can see the scraping of 5th gear dogs sliding out of the slots and across the face of 2nd gear.
If someone holds their foot on the shift lever, it can keep the shift drum from rotating the little bit required to let the shift fork drift over so 5th gear dogs can slip out of the slots...at least until the dogs get REALLY rounded off, and until the gear eats the face off the shift fork as shown here, so it can move as needed to skip out. The PO of Banshee had done it with both 2nd and 1st gears......
If you look in his first two pictures, you see the slot between where the gear teeth end, and the "plate" ring the dogs are on. That slot is where the shift fork sits, it pushes toward the dogs when shifting into 2nd gear, and it pushes away from the dogs when shifting into 5th gear.
When you figure that the amount of material in contct when the dogs are in the slots is less than 1/4", bent is a relative term on the shift fork. with the wear shown on the fork, 5th gear could slide that little bit closer to the engine case when in 5th gear. How close is it to the case in 5th to start with? I never really measured it or paid attention, so I can't say if the wear shown is enough movement to allow contact. But obviously from the last picture, 5th gear has been rubbing abnormally against something on that side.
The last picture shows the side of 5th gear that faces the engine case on the shifter side. With the opposing wear pattern on the gear, it is even possible the countershaft bearing on that side is damaged. Hard to say for sure. Just some things to think about and check out.Last edited by DGXSER; 09-07-2012, 08:31 AM.Life is what happens while your planning everything else!
78 XS750Comment
The parts transmission I bought from Andreas has already been modified, so I may not have to do anything but reinstall them and go.78 EComment
More transmission talk going on here...
78 EComment
